hardtop
I had originally drafted a case design and gave it to a plastic shop to build, but they fell through. Instead, I found plastic cutting boards as a material resource at a local restaurant supply store. They had blue cutting boards :D For this build I felt a bottom would be helpful so I don't drop the batteries out from not enough compression and I won't over-compress trying to squeeze the batteries so they stay together.
The threaded rods and nuts are stainless with galvanized washers. The screws are all stainless from Ace Hardware. I need to get cabling, an inverter, charger and a new BMS.
The JK BMS I got from the batterystore was DOA, so I ordered a Smart Jiabaida (JBD) 4S 12V 200Afrom srikobatteries.com. Once the new BMS is fit, another plastic piece will act as the top that slides in-between the sides to cover the terminals and to set the charger and inverter on top of.
