thanks for mentioning airflow resistance adding up and causing various dangerous failure modes.Beware of exhaust back-pressure. Those little generators tend to have issues with extending exhaust line; it may not show up at first, but over time they get gummed up and fail.
Not from this scenario. We're talking about actually piping the exhaust outside, not just dropping a generator near an open window and calling it good.If the garage is attached to the house I just would not do it at all. So many people here in Florida die from this scenario every hurricane.
I don’t disagree, I will however note when I read these stories they tend to be “relatively obvious” failures to provide any level of safety.If the garage is attached to the house I just would not do it at all. So many people here in Florida die from this scenario every hurricane.
Most internal combustion engines are designed under assumption of back pressure on exhaust in the range of normal atmospheric pressure.I've seen people weld a threaded pipe fitting to the exhaust port.
Why not crack your garage door for supply air?
In both instances you’re explaining a scenario with obvious ventilation INTO the occupied space.Even with the door wide open, it is possible for the CO to back up into the home. Without so much as 5 sides around a generator, just being outside near a window, this has happened.
Portable Generator Placement for Safety | Norwall
Avoid Carbon Monoxide Poisoning. CO is Deadly Dangerous. An odorless and colorless byproduct of internal combustion engines and carbon based fuels.blog.norwall.com
"In Newark, New Jersey, two nineteen-year-old girls were killed by carbon monoxide from a generator placed outside their apartment window."
Although I don't know for certain, I attribute a splitting headache to sleeping in my car (ski area parking lot) adjacent to a motor home with generator running.
Unlike cars with O2 sensor and closed-loop fuel injection plus catalytic converter, portable generators emit high levels of CO.
Also, even though you might duct exhaust outside, there is blowby past the rings. Old engines just let that vent through crankcase breather but newer models do such that into engine. Still, you don't want any fumes from around the engine getting into house. I think engine needs to be kept in a negative pressure enclosure with air exhausted where it will leave the area.
Your RV scenario seems the exact same to me, powered ventilation into your vehicle from exhaust gasses outside.
I’d also bet neither of those scenarios had any form of CO alarm.
I’m not against wiring something like that in, I just REALLY don’t expect to need to do any of this. We’re not in a hurricane area, generally speaking our biggest threat is winter storms and even then, our utilities are underground and we have an exceptionally reliable power grid. I’ve lived here my entire life and it’s never been an issue.Wiring a CO detector to a relay to auto shutoff the generator could be done for the price of an interconnectable co detector a relay small battery and could be a life saver no mater where the generator is located.
If the goal of the project is to reduce noise and prevent theft I think there are other ways to accomplish the same goals with less risks and have other benefits like using the exhaust to heat water for bathing / space heating as an example.
How much fuel does the generator use per hr? How much fuel do you have on hand? An extended outage may not look like we expect it would. Puerto Rico was without power for months, if anyone here lived through that and has some lessons learned I'd like to hear them in case such a thing happens in my neck of the woods.
I’ve done a really crappy version of this test and painted/stained things in the garage with no ventilation, other than me walking in and out through the man door and boy, my wife will let you know it stinks lol.No powered ventilation. Just sleeping in my car, and ambient exhaust from neighboring parking spot.
Don't know for sure it was CO.
No, they didn't.
First step would be to close your garage door and release a smelly gas into the garage. Test with your nose to see if you detect it in house.
Can you situate the generator somewhere outside with no possibility of gas intrusion and bury a wire (not conduit)?
Cars have engines , and you're sat in a metal box with it .RVs have generators in a compartment. Is it 100% sealed from living space?
Firewall may or may not be well sealed.
I totally get where you're coming from. I hope to never need to do it. But, I think it's worth testing to see what the real world numbers look like.Police Ford Explorers were gassing the officers to sleep whilst sat idle with the engine running. they had to modify the tail pipes. Or was it a doughnut sugar coma ?
Anyway, you seem determined to do it, just don't knock yourself out.
