This settles it, I’m going to make a video of it for YouTube.
You just wait, this will have all the incredible cinematic features of a high budget Hollywood Blockbuster film.
“Here I am in my garage trying to see if I can survive the 79cc propane apocalypse”
I have two Wi-Fi connected CO detectors on the way for purposes of the test, along with existing detectors in the home.
Heck, I'd like to think even talking about this idea at all shows how serious I am about mitigating risks.
Ford Explorer is likely a 5,000cc engine, burning gasoline, with powered ventilation blowing air into the vehicle from outside.
I'm looking at maybe, once in a blue moon, considering running a 79cc propane powered generator just above idle in a large room
Livestream. Then you can get "likes" etc.
Does the system "fail safe" or "fail deadly"?
Your live could be hanging on by a thread.
Off the shelf generators these days have CO shutdown. At least start with that, then add belt and suspenders.
Mitigate ... or Eliminate?
Do propane generators emit carbon monoxide? - Sky Stream Energy
https://www.youtube.com/watch?v=-Y-2eGDClqwwww.skystreamenergy.com
I think that shows 69 ppm from a portable generator.
Modern car might be 1 ppm. (the Ford referred to above probably not modern.)
79 cc x 69 ppm = 5451 e-6 cc of CO per revolution.
5000 cc x 1 ppm = 5000 e-6 cc of CO per revolution.
And the award goes to ... the portable generator.
Besides more total CO, a greater (and harmful) concentration even without recirculation.
Carbon monoxide poisoning - Wikipedia
en.wikipedia.org
You'll probably survive. Most people do. ??
10 feet horizontally with bends is a lot worse than 10 feet up vertically. I meant gummed up euphamistically, didn't mean just carbon buildup; there are a whole host of potential issues.I agree with back pressure, however I should mention (if I already haven’t) this generator would be running on propane and my transition to another exhaust system would be upsized. Outlet is .75”, I’d transition to a minimum of 1”, possibly 1.5”. Length of exhaust run wouldn’t be more than maybe 10 feet.
Currently there is no "system" to fail safe or deadly. I sincerely appreciate your arguments to keep me and my family safe, there is no question there.
800 ppm (0.08%), (0.8‰) | Dizziness, nausea, and convulsions within 45 min; insensible within 2 hours |
Finally, they post this, which kinda steps on everything else they've said, notice the "indoors and outdoors" part:
It does.Does the generator have a key? Perhaps one could take other measures to guard against unauthorized generator use.
The heater I have is actually natural gas, which I *should* have a darn near unlimited supply of. I have similar concerns with the CO output, but I've seen plenty of tests indicating they do just fine inside homes. This is the unit I have: https://www.amazon.com/gp/product/B01DPZ56OGIt's doable with the correct cooling ventilation and exhaust as many have discussed. I'm wondering if you'll get more heat per cubic foot of propane from the heater you have as opposed to using that propane to fuel a generator and then power mini splits?
My dad had a gas heater similar to that. Several of them actually. He had a gas well on the property, so unlimited free gas. I questioned the wisdom of unvented gas heaters a few times but he used them for years with no apparent negative effects. Natural gas has a lot of moisture and the inside of the windows were dripping wet on the coldest days. They work without electricity and put out tons of heat.The heater I have is actually natural gas, which I *should* have a darn near unlimited supply of. I have similar concerns with the CO output, but I've seen plenty of tests indicating they do just fine inside homes. This is the unit I have: https://www.amazon.com/gp/product/B01DPZ56OG
Everything in this entire thread is unlikely. It's very likely we'll never face a long term power outage in the middle of winter, while it's also very cloudy for days on end.
1. I have solar
2. I have batteries
3. I have blankets
4. I have multiple 4WD vehicles
If all of that fails, and I need some additional power, whether that be for heat or for supplying power to lights/fridges/wifi etc, then I could consider running this little generator in the garage for supplemental power.
In all likelihood I will spend money to develop yet another backup system that will never be used and this will all have been nothing more than a thought experiment. I'm certainly not planning to be doing this on a daily/weekly/monthly basis. More of a disaster prep scenario.
Oh man, having a natural gas well would be awesome. I'd just run a power plant from it year round.My dad had a gas heater similar to that. Several of them actually. He had a gas well on the property, so unlimited free gas. I questioned the wisdom of unvented gas heaters a few times but he used them for years with no apparent negative effects. Natural gas has a lot of moisture and the inside of the windows were dripping wet on the coldest days. They work without electricity and put out tons of heat.
In my professional career, equipment failures can mean lives, so I’m all about redundancy and multiple backups for the redundant systems. Never using it is never a waste, it means you did your job. Don’t allow yourself to start thinking that planning ahead is frivolous. Murphy never sleeps.
As to your original post, I’ll go back to my dads place. He had an old Onan CCK 4 pole generator. It was in a former coal cellar attached to the basement. The exhaust went through a wall to the outside. The air intake for the motor cooling consisted of a shroud on the front of the motor pulling fresh air from outside, with the positive pressure in the room venting through a vent on the ceiling. You could achieve the same effect with a window fan in the garage blowing out and a small space under a garage door.
Totally agree, if you look at my most recent post just above yours, you’ll see how unlikely the use of this scenario is. If I ever did use it, it would be my main concern for the day. I wouldn’t just be sitting back and “hoping” everything is fine.My dad had a gas heater similar to that. Several of them actually. He had a gas well on the property, so unlimited free gas. I questioned the wisdom of unvented gas heaters a few times but he used them for years with no apparent negative effects. Natural gas has a lot of moisture and the inside of the windows were dripping wet on the coldest days. They work without electricity and put out tons of heat.
