corn18
Village Idiot
- Sep 9, 2021
- 676
Below is my current install with my Victron Multiplus II 12/3000/120x2 50 in my RV. When I am hooked to shore power, it buzzes all the time. Not real loud but I can hear it all the time and it drives me nuts. I don't need it 99% of the time when hooked to shore power, so I want to make the buzz go away. I could move it, but it is in a great spot with good airflow (a/c) and very close to batteries (one foot). The location is right by the access panel where the old converter was, so there is a direct path into the camper for noise. I can't turn the inverter off because it needs power to operate the ATS. If I go charger only, it still buzzes all the time. If I turn off the battery feed to the inverter, it constantly buzzes on and off which is more irritating than just buzzing.
I am going to buy a manual select switch so I can bypass the inverter and then turn it off. The manual select switch will route power directly from the shore power input to the AC panel in the camper. Then I can turn off the inverter and no more buzz. I lose charging but solar handles that. I lose battery backup, but I can just turn the inverter on and not bypass it if I need battery backup. I lose power share but I can also just not bypass it if I need power share. 99% of our camping so far is at campgrounds with 50A service, so I do not need the inverter for that. If I need to charge the batteries with shore power, I can just not bypass the inverter.
This is the selector switch I bought:
This is the new diagram:
Any other ideas?
Any other ideas?
