Thanks for the response. I think you misunderstood my option 2. I would also have the battery in the house as well. No way am I running all that copper to the house from a Seacan as you call it.1) Every State has it's own rules about what does or doesn't need permits / inspections etc. Some regions/counties have ther own "bit" too.
2) DC is not meant for long distance. The battery packs need to be as close to thw inverters as possible. So installing batteries, Inverter into the Seacan with Solar on a rack mount (either attached or not to seacan) and then running your AC power out to the Target Structure is the simplest and most "isolated" PLUS the Least Expensive... You have no idea what 100' of double 4/0 would cost you. (nutz)
3) ON Grid Connected for a Feed In Tariff situation, things are complicated, needs permits & inspections. (Most Commonly)
4) OFF grid with no feed to Grid can be simpler but that varies from region to region...
5) Insurance Companies CANNOT BE FORGOTTEN, they can be such a PITA. They will make complications and want inspections etc... Never forget those bums, any excuse to deny any claims...
I had an epiphany today on where I can place the Seacan so as to keep the distance short as possible (maybe 100') and it would not be entering the opposite end of the house, it would be in the garage with my MSP, my offgrid MSP, and my batteries and inverters. Only downside is I am going to cut down some trees to clear a solar path, but it's a win because it's easier to have them deliver it and it's the most hidden from all but one neighbor, and I like fewer gripey neighbor risks.
OR I put everything in the container and do the AC run (but with my epiphany I no longer have to run overhead, and could pretty easily trench and conduit the AC line. Still on the fence. I do see Option A being the safest option if there's a fire.
