It would be better to locate the 6500ex's at the house.
And let the higher voltage solar DC travel the distance.
Make the power, where you are using it.
I’m having to rethink putting the inverters at the shop. After measuring (I ball parked initially) I got 100 feet between shop and main panel at meter.
I ran thru the calc pvgirl mention and 4 awg would meet the factors she mention, except for derating. I’m stuck on that. I am going to have 4 6500ex inverters total, 2 sets of 2 running split phase.
1 set will feed the house 100feet away, so that’s 3 #4awg wires ac out.
The other set will feed the shop and well pumps…wire already there for that, and the stove back at the house…there is #8 already in the ground from shop to house.
I would also like to feed the inverters with AC IN via 3 #4awg for each set.
I am pretty sure I can run 9 #4 in 1-1/2” conduit…unless the parallel circuit thing, which I don’t get yet, messes that up.
As far as derating, i think I take the 90 degree C column which is 95amps and derating 70% for 9 ccc which is 66.5amps. I used 55 amps for the voltage drop at 100 feet and was ok at 2% round trip (200ft) or 3% each way (100ft). So I think I’m ok…can someone confirm?
Lastly, since there is already a #8 ground wire running back to the main panel, would I need to run any addition ground wires back to the main…can I just ground things at the shop and let the one #8 ground handle the faults.
