cknschneider
- Oct 28, 2022
- 7
I'm a novice solar enthusiast, but I have 2 new GROWATT 3k inverters, 32 240W solar panel (2 rows of 16 wired in parallel, the 2 rows in series).
Batteries are new lifepower 200 amp, and I have 5 in the rack.
It's almost noon, bright sun, batteries are at 74% and it's using grid to power the house and charge the batteries.
It's using most of the defaults, pgm 1 is set to SBU.
I've played around with every configuration that makes sense to me, but can't get it to use solar when it makes sense to.
You can see it connect occasionally at 50-60 volts but the voltage quickly drops back down to 26 and it disconnects from solar.
The only time it uses the solar consistently is early morning and late afternoon when the panels are mostly shaded.
Hoping someone can help - feeling like I just waited a lot of money ...needless to say, my wife is not happy :--------/
