I ordered a growatt Sf 5000 with the transformer.
The mppt is 434 volts and 18 amps.
How many panels can I hook up in series on one string if each pannel VOC is 49.6 volts and the ISC is 13.45 amps and the watts is 530? I think the answer is 8 but since this is my first off grid set up, I want to check with you.
Second question is since it is in series can I really just plug it straight into the growatt inverter. OR so I need a fuse and a cut off switch?
Thanks Greg
Thanks Greg
