Hello Labeeman, In didnt know that it was a link to the device in meer. Sorry for that. Thank you. Ik couldnt find my invoices but i think it must be somewhere about 150 kW montly in winter and about 120 kW in Summer
You use only use 5kwh a day at 150kwh a month. It might pay you to look at what is the biggest power users you have you may be overpowered on the inverter.
U verbruikt slechts 5kwh per dag bij 150kwh per maand. Het kan u lonen om te kijken naar wat de grootste stroomverbruikers zijn die u heeft, mogelijk wordt u overweldigd door de omvormer.
thank you for that Labeeman. You mean that the Growatt is much more powerfull than what I need? If I understood that well: dont worry, once I have it working i will wath much more my personal cinema and other devices that I am not using so much now cause of the kWh price from the companies here.
The bigger the inverter the more power it will consume doing nothing and taking up more battery power when there is no sun. you need to see what you are consuming.
