Hi Everyone,
This morning while the sun was not up yet and the PV were barely picking up I got an error 5108 or 08 Bus voltage high (Fault) while charging from the utility. I restarted the inverters and everything worked out fine.
The setup is as per the following them as per the following:
What could be the issue?
- 2x SPF 5000 ES running in parallel (firmware: one inverter is 040/041-05-701 and the other 040/041-06-104)
- 10x Longi LR5-72HPH-545M (each 5 panels to an inverter)
- 12x Lento lead acid LSTB-22000 (12V 200Ah) - installed each 4 in series (48V 200Ah) and then the 3 series in parallel resulting in a setup of 48V 600Ah -> 28.8 Kwh
- The whole system is also connected to the utility as well.
Program | Value |
1 | SUB |
2 | 70 |
3 | APL |
4 | DIS |
5 | USE |
6 | DIS |
7 | DIS |
8 | 230 |
9 | 50 |
10 | 4 |
11 | 30 |
12 | 46 |
13 | 54 |
14 | SNU |
15 | ON |
16 | ON |
17 | ON |
18 | DIS |
19 | 56.8 |
20 | 51 |
21 | 45 |
23 | PAL |
28 | 1 |
37 | 2022 |
38 | 5 |
39 | 18 |
40 | 10 |
41 | 0 |
42 | 0 |
43 | DIS |
44 | 58.4 |
45 | 60 |
46 | 120 |
47 | 30 |
48 | OFF |
49 | 0 |
50 | 0000 |
