I just set up an SPF 6000 ES PLUS but suprisingly couldn't find anything in settings where I can select "no battery". It's a temporary situation until the battery arrives but we want to run it with solar and grid only to take advantage of the solar power instead of waiting for the battery to arrive.
So as you guys suggest above, I guess I can ignore what battery type is selected and let it run with the error/warning?
The thing is, if you do that, you can measure voltage (55-58V) at the battery terminals of the inverter, it tries to charge a battery which doesn't exist. Also, PV output is not being sent to the loads, only grid bypass is happening. Any thoughts?
Even if I get it working somehow, I'm surprised why Growatt would not add another battery mode called "no battery" and disable the battery feature. This way there would be no voltage at the terminals and also no error/warning when a battery is not connected.
