I just repaired one of my stripped threads and documented the process of drilling/tapping/helicoil'ing them in a video:
It's *so* tempting to do this to all my cells and just be done with this 6mm-in-aluminum nonsense.
Just watched your video again. Looks like you used the 6th-biggest thread guide for the tapered bit, which should correspond to 19/64” or 7.54mm.
My tapered bit won’t fit into my 7.5mm hole so I guess I’d need a standard tapping guide for that.
On the other hand, I’m pretty much touching the bottom with the tapered tap so I think I’m past the point where that will help.
Pretty sure I’ve cross-threaded the top two partial threads that are left, and the bottoming bit inserts a full two tapered threads before hitting, so I think my best bet may be to use the bottoming bit on the 7.5mm hole and hope is stays straight enough to get a thread started.
I did forget to use tapping fluid when I tapped the tapered bit, so not sure whether that may have resulted in the snafu I’m dealing with now, but I just did not get ~2 threads nicely formed after using the tapered bit (by hand using the drill press in my case).
I’ll get some aluminum and practice with the tapping guide as you demonstrate so I hopefully get some sense of what things should feel like once a thread has been properly started.
Whether I can salvage the thread I (mis)-started in the stripped cell or not remains an open question, but at least I should be less of a neophyte for next time...
