Not sure if what I am adding will help as my issue appears different but I do wonder if they may be some related factor with my issue.
I am running a single unit, Growatt 24V SPF 3000TL LVM, and I am also not running enough panels at the moment that I have the issue of losing solar energy, my issue still relates to the charging of the unit though. My settings are as follows ...
Whenever the unit begins charging with the utility, it never reaches the bulk charge before it stops charging. Charging usually stops at around the 27V mark and I have yet to understand why it does. During the day I get about 1-2kw of solar but my bank is almost 11kw so I do use the utility to charge the remainder of the battery. My current load will use the 11kw in a day or 2.
My experience might be completely unrelated to the topic of this post but I am at a loss to understand how or why the Growatt behaves how it does for my system and my settings.
