Confusedcoconut
- Apr 10, 2022
- 7
Hi.
With the growatt spf5000es being a offgrid inverter am I right in thinking I need to have a rotary changeover switch to completely prevent any backfeeding into grid and run all AC through the growatt like so?
Then in the unlikely event I should need intensive power consumption the 5kw unit cannot handle I can turn off the AC isolator to prevent backfeed and change the rotary isolators position to feed the consumer unit and not the inverter?
(I'll be getting an electrician to do all final wiring and check it off)
