Hi there, i have been reading the forum for some time and watching Will's video and have finally made the jump to build my system in my van here in the UK
so far i have bought a 48v Fogstar battery 5.12 kw/hr server rack battery
and i have plans to buy 4 x 200w mono solar panels
i would like some advice on the best AIO most likely MPP solar, as they are reasonably easy to get to the UK, (i looked at EPG4 and Growtech but they seem harder to get here) i would like remote monitoring preferably something I could add to a raspberry pi running home assistant to show state of charge at least, but if not at least some information in the living area as the AIO will be hidden away.
i am currently looking at the PIP5648MT, mainly as it is one of the few 48v AIO that has a 60v minimum mttp range ( as i believe it will have to be that low for my small array to work??)
i take it is possible to remotely turn off the inverter with an AIO?
so my questions are:
is there a better option for the AIO that you would recommend
also, i am also thinking of adding a Sterling 12 to 48v b to b charger,
would this work for me? is there a better option?
also is there a high amperage 48-12v step down you would recommend? as i have a 44 amp car stereo upgrade i would like to power off the leisure battery as well as the usual fridge, lighting, and 12 v systems.
thanks for taking the time to read this
Sam
Fogstar Energy Server Rack Battery 48V (5.12kWh)
UK-designed Fogstar Energy SR51.2V Lithium (LiFePO4) Server Rack Battery with heating, pre-loaded inverter protocols, LCD touch screen, 16 Grade A EVE Cells, a DC Rated Breaker and an 8 year warranty.
www.fogstar.co.uk
12V (only) to 48V Battery to Battery Charger w/ reverse charging feature + Jump Start Assistance
12V (only) to 48V DC to DC Chargers 115A input and 26A output model (1600W input and 1500W output) - E-Marking | BB1248120 If you need 24V input and 48V - click here Also, new to Q2-Q3 (early summer 2024) - BB124865 - a smaller / lower powered derivative of the BB1248120. 12V and 24V input to...
sterling-power.com
Sam
