Hey guys, so I'm building a relatively high voltage system: 48v to cut down on wiring costs and other losses.
Anyway, I will be running as much as possible off DC (fixing old fans using DC motors, LED lights, etc.) so I can keep the price for my inverter as low as possible.
This got me wondering if I could find any high voltage lights instead of having to step down everything to 24 (or lower) volts.
I also have in mind to keep my home made cheesy solar panels and Lead acid battery around for emergency power for lights in the rainy season (when my not yet built LiFePO4 bank may run out of juice).
I found these cool LEDs online that claim they take a voltage range from 12v-85v !?! So with these things I could have a switch when the juice runs out on my 48v system, and switch the old 12 v system (for lights and smaller fans).
There is no real spec from the seller and I googled around a bit and couldn't find anything.
Does anyone have experience with this kind of variable voltage in lights?
I'm wondering do they each have like a buck converter built in or something? Are they efficient? They are not expensive either; like a buck (pun intended ) for some of them so I'm wondering about what's going on. Any ideas guys?
