Exactly.I believe that what he meant was that if one cell shorts, the pack voltage drops with 3.2V, meaning a potential difference of 3.2V between that pack and the others in parallel with it.
Again, this is not about the BMS....Call me weird but I don't want a Seplos BMS. I keep seeing where they mess with it and v3 is not as good, or something. I dunno.
Part of me wants to get JK BMSes, another part just wants to retain the JBDs I have (with 300A contactors LOL overkill) just because I own them already.
Maybe all it would take to make it "work" with 230Ah is to just put a spacer block in the back of the case to account for thickness difference. I should check cell dimensions.
I'll take my discussion to the Luyuan battery box thread as to not junk up this one with my ramblings and musings.
What if 1 hot cell started melting the plastic wrapper, shorting 2 cells case-to-case? A chain reaction could commence shorting one to the next as the heat grew.
And to add, this is now the third time we've seen something like a fire or a burn where this BMS was involved..Call me weird but I don't want a Seplos BMS. I keep seeing where they mess with it and v3 is not as good, or something. I dunno.
This is my summary of the fire. The Cells are arranged in 16s x 6 with fuses between each bank. After the fuses the banks are then connected together with a copper busbar. In order for one of the fuses to blow, then there would need to be current flow of in excess of 200 amps. The fuses were not type T fuses, so once the fuse melted then it continued to arc causing a fire.
The root cause would have to be one of the Cells that became shorted. That would drop the voltage down so that the current would flow from the other 5 banks to the bank with the defective Cell.
There was an indication of issues with the Cells from Xuba from the leaking Cells. The leaking Cells were replaced, but there were possibly others that just needed to have more time before they went.
The Cell that became shorted would have had to be a sudden event. The system had been working fine for years, and was working fine the day of the event. It wasn't until the sun had gone down and the system was in discharge mode, that the event occurred.
The system was put together in a meticulous manner and a lot of thought on safety was evident in the displayed results.
The Cells were all on a metal shelf and monitored, and still his house is destroyed.
This is all speculation, of course.
I believe that how we treat our Cells is very important. The Cells should be treated gently and not abused by excessive charging or discharging, above or below the knee.
Regular Cell monitoring and balancing should be a daily regime.
My thoughts are that LFP technology is still one of the safest Cell technologies that we have. This is evident in the direction of EV manufacturing. It also makes me question some of the Cells that do not make it to EV quality. Are we risking our homes to save a few bucks?
My conclusion is that the only way to be entirely safe is to remove the hazard from your home.
I'm not blaming the BMS.And to add, this is now the third time we've seen something like a fire or a burn where this BMS was involved..
The first one : cheap powerwall, not build according to spec and leaky cells, yet the BMS was blamed at first
Second one, was a axepium box ( mason 280k rebadge)
Turn out a manual instruction issue and missing crush rings..
Again BMS was blamed until details came out
Here we don't know what exactly went down, and it is all speculation..
Weather this was an internal shorted cell or a fuse that arced, or simply wrongly assembled packs...
Untill we have more info we will not know, but it is all too easy to blame the BMS yet again, most likely wrong again
Which is absolutely fine , for those other reasonsI'm not blaming the BMS.
I'm just saying I don't want a Seplos BMS for other reasons.
Effectively, 7-15kwh batteries using all one singular BMS? That doesn’t sound fun at allThe pictures only show 6 strings, but in the build string where he replaced the leaking cells he shows where he had 7 strings made with 112 280ah cells. Also if you read the whole thread where he is building out his battery banks he started in a black metal cabinet then moved to a long wall of cells.
So 7 strings * 16 cells all using cell top balancers controlled by a single BMS. Interesting way of doing it but has the benefit of one controller keeping all 112 cells balanced. And the balance leads don't need any special identical length because the cell top balancer just lets through enough current to do the job. I believe he is using a 2 amp model of this.
I agree it was likely a venting cell that caused overcurrent to blow a fuse that caught on fire providing the spark.
It's a Batrium, they are designed for that and more.Effectively, 7-15kwh batteries using all one singular BMS? That doesn’t sound fun at all
Oh my !Effectively, 7-15kwh batteries using all one singular BMS? That doesn’t sound fun at all
I don't think running seven strings in parallel like was being done is a supported configuration from Orion. I believe they would spec one watchmon and shunt per string, not one watchmon and then multiple parallel strings.It's a Batrium, they are designed for that and more.
Using 112 Blockmons (one on each cell) to a single Watchmon still does not sound fun.It's a Batrium, they are designed for that and more.
I bought a flir, but what is considered "hot"?I am glad i have my thermal imaging attachment on my ipad.
It is an invaluable tool for stress testing builds.
They arent cheap, but they are amazing and im thinking a DIY necessity.
Almost every page of that document warns against running multiple strings in parallel without taking specific safety measures to be able to disconnect each string automatically, the section about the dangers of eddy currents foresees an issue where a single cell failure could cause a cascading issue that moves from string to string.Batrium has a 17 page document specifically about parallel systems
In the OP build thread @Ampster says he too was running a single batrium on 2 packs and was facing some difficulty. Idk what his resolution was, but at the time he mentioned adding more BMS instead of sharing
Batteryhookup has the tyco 500A relays for peanuts if you weren't aware, they have a version with fuse already attached sometimes.This gives me an idea how to better protect parallel batteries. Install current shunt or hall shunt and contactor on each series string. If current sharing suddenly deviates from equilibrium then disconnect offending string. Doing this prevents other good strings from dumping current into shorted string. The hardware to do this already exists on rack batteries in their BMS boards making this only a question of firmware modification.
TE Connectivity EV200AAANA 500a 0-900vdc Tyco 12/24v
These were recovered from EV battery modules. These are VERY EXPENSIVE online. If you have any project that needs a high current relay this is your chance to save some money. Make a cheap 30a BMS into a 500a BMS. This will work for batteries in the 9-36v range so perfect for Lifepo4 and Lithium...batteryhookup.com
