raurre
Since there is a permanent battery bank attached to the inverters there's no need for a pre charged resistor. The inrush between the two battery banks is less than you would think and depends on the SOC difference between the two. Like I mentioned earlier, I can only speak to my own system. I only connect or disconnect it when the system is not under a large load. This is the system I am referring to Thread '4 MPP LV6548 / 30 kW EVE 304ah LiFePO4 battery/ 14 kW PV array' https://diysolarforum.com/threads/4-mpp-lv6548-30-kw-eve-304ah-lifepo4-battery-14-kw-pv-array.32343/
