LasseH
1)The goal is to not put any power back into the grid. 2) …While also saving money.What's your ultimate goal in using the solar system? Just as a backup in case the grid goes down or to get you using less grid power?
I’m starting to think that unless I get a solark 15K and tie the main two power leads from the grid to the inverter, and then take the output leads back into the main panel. (Expensive as it is)… I would NOT NEED a sub panel. And it would even be dumb to get one.
Also, even if I got a megarev/EG4-8K (sol-ark clone) to offset the consumption, there would be no guarantee that the CT measurements would even engage or disengage the inverter to offset the consumption. (Settings seem like a hassle to configure and set up), so I would HAVE TO get a sub panel.
Would my assumption be correct on this?
