timselectric
- Feb 5, 2022
- 18,619
This depends on if the AIO's are high frequency or low frequency.Agree: When a Single AIO produces L1,L2,N with one unit, and multiple units are described as parallel by the manual only to increase output capacity (Voltronics example MPP6048)
Vs Creating the split phase using at least two AIO units and adjusting the settings such that the two units (or more) together create 120-N-120 (Voltronics example MPP 6548) in the settings the user can select for example 120-degree angle for 208V 3P or 180-degree angle for 120-240.
A single low frequency unit creates the split-phase on the secondary side of a transformer, with a center tap.
A single high frequency split-phase unit is actually two inverters in one enclosure.
Split-phase is created the same way as two separate units.
