OffGridForGood
Catch, make or grow everything you can.
I don't know anything about the SRNE, - can two of these units be set up with comms and run together for future expansion?I'm also looking at the SRNE ASF48100U200-H
Curious.
Nope but for the $950 plus shipping, I'm waiting on a final quote, I'll rewire AC panels and order a 3rd for a spare ?I don't know anything about the SRNE, - can two of these units be set up with comms and run together for future expansion?
Curious.
Don’t spend as much money on unneeded everyday life stuff …SAVE UP….stick to Victron/ Schneider/ BB/ MS/ Blue Seas .……and other top tier stuff ..I live about 2 hours from SS and could easily drive there for sales and support, but the horror stories I'm reading in these forum threads have given me serious pause. What else is out there that people tend to consider relatively reliable and affordable?
and those are just the 100Ah rack batteries - try lifting the 280Ah racks ! (about 225 lbs each)That's what I used to install batteries in the rack. Apollolift but same thing. Works great. I highly recommend.
But Jim,.stick to Victron/ Schneider/ BB/ MS/ Blue Seas .……and other top tier stuff ..
It just works.
I understand , but people can normally afford what they Really Want.. it make take some discipline and forethought as to how to adress spending on other stuff…. Life ain’t fair sometimes ..mostly we can’t all have all we wish.. we have to make choices….it took me a while to save to buy top tier stuff and lesser grade pizza and spend less on less important things..But Jim,
The OP specifically said they can't afford Tier One stuff, can't we give our best advice on mid-level stuff, and let them join the party? The potential to learn is so much higher when you have stuff that needs more attention after all!
I envy Musk… lucky rascal…But Jim,
Not for 30 years. Loved my Baldwin mortised lockset and the finish carpenter that installed it. It was another era when I could afford a custom 4⁰ x 8⁰ front door.Not sure you've seen what these go for!
You can buy a decent guitar for 400.00 maybe 600.00It usually takes a while to wear down my resistance and get me to loosen my purse strings.
(metaphorically speaking, of course.)
I've been feeling tempted to get a Baldwin mortised lock set, just because I have an old mortised door, and want it to take the same Schlage key as the others instead of a skeleton key (or more properly called "warded?".)
View attachment 155992View attachment 155993
Same upgrade. A month or two ago as I recall.The Sungold Power sp6548, after briefly looking at them the other day, seem to have gotten an upgrade in terms of their MPPT controllers, as they are now listed as featuring a 390voc limit with a
Wide mppt ranging 90-350v. So given the extra 100v usable range over MPPs LV6548 what's the catch here?
Lv6548 getting upgrade soon too or what?
Are these the same 6548s mentioned in this thread?
...yea Pizza's in today's world. Picked up (2) 3 topping Domino's pizza last night, $45.00. OMFG! Time to shift to frozen pizza & cook it in my own oven. Save up more for DIY batteries. ?I understand , but people can normally afford what they Really Want.. it make take some discipline and forethought as to how to adress spending on other stuff…. Life ain’t fair sometimes ..mostly we can’t all have all we wish.. we have to make choices….it took me a while to save to buy top tier stuff and lesser grade pizza and spend less on less important things..
can we have no discipline in life anymore..?
I aggree it would be nice to afford anything… BUT………..ya know…
I'd love to run the 5 hp compressor on 240V. Back when I had a generator in the back of the truck, I made a suicide cord to run 240V on normal heavy drop cord and rewired the compressor motor for 240V.The key to running motors is be sure they are running on 240v (some motors can be changed from 120 to 240 inside the terminal case on the motor by moving a jumper cable) going with 240 will ensure you have equal load on each leg (L1 L2) for your inverter and it will be half the amperage of running on 120.
Lithium Solar did a video on the 390V units and Ian mentions the 390V units in his description for the 250V units on his website.The Sungold Power sp6548, after briefly looking at them the other day, seem to have gotten an upgrade in terms of their MPPT controllers, as they are now listed as featuring a 390voc limit with a
I can well afford Tier 1 but where is the fun in that?Don’t spend as much money on unneeded everyday life stuff …SAVE UP….stick to Victron/ Schneider/ BB/ MS/ Blue Seas .……and other top tier stuff ..
It just works.
Let discount buyers fuss and fight with China and /or consult forums for resolution on operation and fixes.
in 50 years of buying different gear of many types , I have had two top tier products not work right…TWO… they were promptly replaced and life moved on…
but , maybe that’s just luck on my part.
Thanks for that info. I've been pondering the engine lift and as luck would have it, Andy had a new video last night using one to lift a battery. A trip to Harbor Freight is on my itinerary for the weekend.I'm same age as you and do everything (technical) solo. My wife around 90 something pounds would only be in danger.
Engine hoist works. You may be able to use it as-is, but I added an extension pipe to get 18" beyond the front wheels, and put ballast on the back.
How does a 140 pound weakling hang a 140 pound inverter?
When I hung my original 2.5 kW SWR-2500U inverters 17 years ago, I was probably stronger and they were only 75 lbs. I was able to carry them up a stepladder and hang them head high. Taking them down to upgrade was doable, but difficult When I hung 75 lb transformerless 10000TLUS under the deck...diysolarforum.com
