D
Deleted member 9967
Guest
Ok so I finally got my new cells after the others were found to be bad.
I series charged them to 3.65 volts. I then lined them up in parallel and charged them up to 3.65 volts each to top balance them.
I then let them rest for 24 hours and the cells are 3.335 volts each now.
Is this normal?
Thank you.
EDIT: They are 280 Ah lifepo cells in case you need to know.
Is this normal?
Thank you.
