stuffnjunk
I have been watching countless videos, read William's book, read some peer reviewed journal articles regarding bifacial panels in northern climates, looked at several manufacturer's sites, and all I can say is I am confused as it appears I am entering this area as the tech is changing over.
Just some background information for those who would care to respond. I currently have a home in PA with several acres of unobstructed and open land on which I would like to mount a ground array consisting of bifacial panels. I am also considering, due to wood pellet and oil costs soaring this year, removing the pellet stove and installing a mini split (s) in my basement. Pellet stove only heats my basement. I would also like to have some battery backup capacity. I own the pole on my property from the utility, which has to have the meter on it and a disconnect. I then have about 100 foot run to the panel in the home. From the home I have a sub panel which runs to the pole building with a panel. I already own a winco 10k generator for outages, which I have mobile in my pole building and setup to backfeed through the sub panel (to eliminate noise and to hide from thieves) for critical loads like the furnace and fridge freezer. Most of the work I have either done myself, with an electrician, or I hired an electrician to do. I am fortunate in that you can't swing a dead cat without hitting a lineman in my area.
Pellets went to about 310 a ton this year and I go through about 2 ton a year (were about 200-230 last year and I buy them straight from the mill). SO the cost of the pellets, fuel to go get them and return, the work to unload and load in basement (I have a tractor with pallet forks so it isn't too bad), coupled with the increased electricity costs this year and the yearly maintenance cost of the stove has me rethinking things. Plus I am getting older and my knee is kinda sketchy.
PA has net metering but penelec subtracts the distribution charges selling back, but the srec credits are about 31 (last I looked) 30 percent fed credit, and if I build about a 9k system, I'm looking at too many variables to get a real ROI, but from what I have read and the videos 8-10 years seems like a good SWAG. Most of the work I will do myself, or do the quid pro quo method with a lineman, or when neither works just hire someone.
Questions/concerns:
Can I use my winco gas powered generator to feed the batteries in one of these all in one systems if I am not producing the solar needed and there is a blackout? I hear them talk about it, but I am not seeing videos showing it.
These all in one setups are the current tech? I'm referencing the cube as an example. It appears pricey compared to buying parts.
Why am I looking at bifacial? I live in the north, I get snow and cold weather, and 2 peer reviewed journals can't be entirely wrong can they? I understand the increased cost of these panels, but in an SE-SW configuration on a hill top with a steeper angle and reflective subbase, with about a meter to a meter and a half placement off the ground, it seems like the logical choice. Maybe I got too into it and this tech is too new to know. I'm not worried about moving them (their weight), I have a 50hp tractor and pallet forks and can move a ton of pellets on a skid.
Is the meter collar a gimmick? If I am backfeeding the grid through my house then through 100 plus feet of line to the meter with disconnect, I don't think it would help me. I really don't want to run lines through my front yard again. That was a PITA 16 years ago with the cable, water, sewer, power, and inspections.
Side note, I am in my offseason from my side hustle and am retired from full time work. I am currently consuming2-4 hours of reading or videos a day to educate myself but no one to bounce ideas off of. sorry for the long post, and maybe it went sideways from my original intent.
Questions/concerns:
