I have a 1.2Kw(1.8kw surge) 12v PSW inverter which happily runs approx 50w constant (300w peak) of load @ 225v 24/7. When I change the load circuit to a constant pressure water pump that uses 650w, the inverter drops down to ~80v and of course doesn't provide enough power to run the pump. What could be the issue?
I have 2*12v/65ah AGM batteries in parallel. A meter on the inverter dc load side say the inverter is pulling 56amps @ 12.6v, which i believe to be in the ballpark to handle 650w @ 225vac (~3 amps.) for short periods at least. The pump works fine connected to the mains.
Before I start replacing the inverter (maybe upgrade to 24v inverter & changing the battery config to serial are my next moves to reduce the dc amps), can anyone point me where I'm going wrong as my beginners brain says this should be working.
Thanks
Thanks
