Out of the box should be fine.Do I need the DC cables connected first with DC power applied or can I just do it out of the box.
Surprised the resistance is that high.equipment ground and ac ground .5 ohm
Floating neutral.equipment ground and ac neutral. Open
expectedequipment ground and ac hot. Open
Floating neutralac ground and ac neutral. Open
expectedac ground and ac hot. Open
I guess that is correct.dc negative to equipment ground. Open
dc positive to equipment ground. Open
Back to chit chat after that tech break!
@Brewman, when you wear the patch, maybe you can be my trustworthy foe...
(From my Wen drill press manual)
