Mic the Vegan YT
- Feb 14, 2020
- 10
Hey guys,
I am sticking hard to a 12V system because I don't have to run cable far and made the mistake of pouring money into a 12V pure sine inverter before learning anything. So my 1,500 watt system is going to need a lot of amperage of charge controllers. Right now my idea is a DIY lifepo4 system with 3 Renogy 40 amp mppt charge controllers. They can do 8 awg and with 3 legs of 5 x 100 watt Rich Solar poly panels at 5 to 6 amps each I would be looking a 25-30 amps for each leg. In other words it would be...
3x: 500 watts of panels at 30 amps max + 40 amp Renogy mppt.
I know you can do 2 charge controllers with this setup but would 3 get too crazy? How does it work with a BMS? Would I need 3 BMS or just on bulkier one? I will be building a 400 ah DIY lifepo4 bank.
Thanks in advance,
Mike
Thanks in advance,
Mike
