Wow, that really gives a hit to the overall monthly efficiency.Yes, in SUB mode.
The grid and inverter output are basically grid-tied.
It constantly pulls 300 to 500 watts from the grid to make sure that it doesn't export. This is how it handles variable load changes. So that it has time to adjust.
The issue I see is the battery bank is not large enough and PV is not large enough for the loads.Wow, that really gives a hit to the overall monthly efficiency.
If I use generous time periods of daylight, lets say 7 hours in the summer, he is wasting between 2KW and 3.5KW of Grid power daily when he really does not need to. Yes it's being pumped into the battery but if your battery bank is sized to small or just right then it's just wasted energy.
That is about 100KWh per month. That would be a 25% increase on my Grid energy usage each month if I just switched Inverters and used his.
My system could operate right now in SUB mode, it's all ready to go on that end. Still building the battery bank, and ordering more cells soon. The big battery box is coming along, it's been here over a year now. https://diysolarforum.com/threads/house-system-battery-box-hoffman.32305/SUB mode is a budget friendly way to get into solar.
Once you get serious about your system. SUB mode is just a memory.
If you are paying the utility company for all of your electricity, currently. And you already have solar installed. Lowering your utility bill would be the objective. This is how my system started. As soon as I had the solar and inverter installed. I began enjoying my ROI.I have no desire to run in SUB mode at this point, I just don't see the objective.
You have to set it to solar only charging, instead of solar and utility.Actually it is not just SUB, it does it in SBU too once it switches to grid. I cannot set it to not charge the battery. I can only reduce it to 2amp per inverter when in Grid mode. It constantly uses more grid than it should. Totally disappointed.
I have tried that and it does not work as intended. It will use grid no matter what setting when in sbu and after it switches to grid.You have to set it to solar only charging, instead of solar and utility.
Setting #16 I think.
It shouldn't.I meant to say it will charge the battery with grid no matter what setting...solar only, both etc.
Are you using comms with batteries?I meant to say it will charge the battery with grid no matter what setting...solar only, both etc.
I also use SUB mode when severe weather is expected. To maximize battery. Those are the times most likely to produce a grid down event here.SUB mode is a budget friendly way to get into solar.
It needs this buffer current to be able to react to load changes. (At least that's how I'm justifying it to myself)I have tried that and it does not work as intended. It will use grid no matter what setting when in sbu and after it switches to grid.
With my particular off grid inverter the idle power for operation is drawn from the battery which can lead to a dead battery. No leakage current from the AC side. My solution is I am installing a 3 amp battery charger with a timer on the AC in side so the it can be set to run during nighttime hours. Because I will not want this every night I plan to just unplug it when not faced with Winter and multiple days of poor weather.It needs this buffer current to be able to react to load changes. (At least that's how I'm justifying it to myself)
I like this 2 amp 'leakage current', lack of a better term. When my batteries are discharged to the 'back to grid' setting in my inverters, they are low. So then my system switches over to grid and my batteries otherwise just sit there depleted. But this leakage current charges them off the bottom through the night till the sun comes back up and my 'back to battery' voltage is reached.
I don't believe you can totally reduce this to zero.
Except with switches.
Edit to add... I mean, you're already on grid for your loads. It's only adding 1.5 or 1.6 amps beyond your loads. And that is a net charge for the battery.
