OK, I admit I haven't done anything with
MY pristine threads as I have not received any cells yet.
However, I was planning on inserting an M6 Helicoil (based on other discussions) to protect the aluminum threads, but that no longer seems to part of the "virgin" thread discussion? Is that no longer a preferred method to protect new threads?
And if it is still useful, would Loctite Red or JB Weld still be used when a 20mm/25mm SS grub screw is attached for the first time? I was under the impression that the Helicoil would make an even stronger connection with the threads and then some application of a threadlocker or ??? to seal the deal. Obviously, a top hex wrench would still be used hold the grub screw stationary while tightening nuts.
Someone, PLEASE enlighten me! ?️
