It's just easier with the tap handle once it's started. But it won't hurt to go as far as you can. You have to keep pressure on the handle all the time.
Well, I just successfully inserted my first Helicoil.
Got all set to drill a hole with the 1/4” bit when it occurred to me to check that the platform on my press was level. It was side-to-side (which is the direction it can be adjusted). Since I had the right angle there I thought I’d check the front-to-back angle as well, and surprise of surprises, it is off of a perfect 90 degrees.
Probably means this press is worthless and probably also means my terminal is toast (since I drilled by hand using this press), but on with my saga.
I wanted to use the tapping guide to drill a straight hole and since my tapping guide is metric, I couldn’t use the 1/4” bit so returned to the 15/64” bit (which fit pretty snugly in the 6mm guide hole.
Ended up needing to use the power drill but got a nice straight hole drilled, a bit over 7mm, like the hole in my terminal.
Started to tap using the tapered tap and the tap guide and got about 2 full turns done.
First, I used tapping oil this go-round, and second, I followed the suggestion to back off 1/4-1/2 turn after every half-turn. The chip was wedging at about 1/4 turn back, and so by pushing past that to 1/2 turn back, I finally know what it feels like to snap off the chip - in all past attempts, I was backing off only until that point and then worried that I was gouging out the threads I’d just tapped, so I’d continue forward.
Aside from issues with my holes not being straight, I think this is the single most important thing I was doing wrong.
After removing the tapered tap, I switched to the bottoming tap, still through the tap guide. I continued with the bottoming tap until I started to feel the resistance increase, at which point I removed the tap (without cross-threading for the first time ever!), cleaned out the hole and inspected.
I saw nice, clean threads but it looked like there was more untouched cylinder at the bottom of the hole than I saw in yesterday’s attempt so I rethreaded the tap (this time without the tap guide) and got about another full thread tapped by using more force.
Got the tap removed cleanly and counted five full threads down from the top with space for at least one more thread below the last thread that was clearly-tapped.
Cleaned out the hole and decided to try my 6-coil Helicoil (reduced from 7 originally).
Got the Helicoil threaded and it just barely sunk below the surface (with a bit of force - the bottom of the coil started pressing against the insertion tool again).
Like last time, I snapped off the tang by just increasing the insertion force until it snapped. The slot in the insertion tool is once again compressed and squeezing the tang, as well as a visible thread mark at the bottom where the lower-most coil was compressed against it.
I first threaded an M6 bolt and it engaged for a full 4-1/2 threads up to a force of 50 inch-lbs. I then replaced with a grubscrew which engages for a full 4 threads including the tapered end which I may file off.
Allen head in the hex head of the grubscrew looks straight (orthogonal to the aluminum rod) and when I finger-tighten a brass nut on a large lug, I can’r see light on either side and cannot slip a piece of paper in-between. So I think the grubscrew is straight.
I can go to 50-ft lbs on that nut without issue, so 4 threads engaged is more than enough.
Now that I know what tapping is supposed to feel like and I know the 15/64” hole diameter is not an issue, I’m tempted to just go ahead and try to tap the terminal using the same technique.
Again, the hole is probably not straight but reasons it might be is that I used the existing hole (which was presumably straight) to guide down the 15/64” but by hand, which was essentially just reaming out the remaining JB Weld stick against the sidewalls.
So I figure I’ve got nothing to lose. But I’m going to hold off for a day in case any of the helpful crew here have any advice for this tapping neophyte.
Also, since my current process relies so heavily on the tapping guide, I’m going to have to rig up some sort of structure with a bottom board below the cell and clamps to assure that the guide stays fixed/solid on the tiny terminal surface while I’m tapping down...
