just took my golf cart out for first ride.
started Battery was at 92%, ran around for a bit very happy with everything averaging 37 amp draw, climbed the steepest hill amps climbed to 55.
battery level read 88 % then all of a sudden it drops to 11%
I get home throw it on the charger and it starts the charge total battery voltage 53.61. charge starts to climb at 13 %
my cells were balanced before building this pack. low cell is 3.332 high cell is 3.355 then one cell starts to fluctuate between 3.332 and 3.772
now bam it jumps from 13% to 93% this is all in about a 30 minute time span. from start charging to now currently low cell is 3.350 high cell3.355 with one cell (9)fluctuating between 3.354 and3.850
currently total volt is 55.13
this set up is 16s, 105 ah battery with JBD bms set at 250amp. charger is set at 56 volts. floats between 1amp and 30 amp depending on the draw.
any ideas what is going on I do NOT want the wife stuck out on the course.
thank you
thank you
