uksa007
- May 26, 2022
- 239
I assume you have correctly configured the inverter for CAN bus battery, maybe try restarting the inverter, disconnect mains and battery.Hi Uksa007, i have now connected wire as above (2-5 and 7-4) and set the correct dip switches 2 and 3 ON; Battery is not seen on SofarSolar graphic on inverter panel. i tested DC outlet from inverter 3.5V; then connected DC power cable and i have 56,7V, those volts come from battery but inverter is not charging battery; Event list : ID52 BMS disconnected and ID 36 Meter com Fault
Apart from the above, sorry I'm out of ideas, you will need to contact the battery and inverter manufacturers and see if they have any further advice.
