That is about the new inverter BMS.There seems to be an issue with JK? next video show a fix for it.
FYI:
Yeah, it's weird.Bah! No matter how many ways I tried, it would only let me order 1. After ordering the first 1, it let me order as many as I wanted. Go figure ...
Was the price the same after the initial 1?Bah! No matter how many ways I tried, it would only let me order 1. After ordering the first 1, it let me order as many as I wanted. Go figure ...
I figured it out, the first one $5 cheaper is one of those special deals where they limit it to ordering only 1.Yeah, it's weird.
I was limited to 7 in a single order, for some reason.
Possibly shipping box size.
Had to split my order into 2.
When I ordered, I could go up to 7.I figured it out, the first one $5 cheaper is one of those special deals where they limit it to ordering only 1.
I have 6 total on the way.
It depends on how bad the shit hits the fan. lolWith multiple packs in parallel is the extra 50A and 1A balance really necessary?
Too late already bought.You can get the 150A 8S-24S w/ 1A active balancing for $82.12 ea buying 4 or more.
B1A24S15P
JKBMS Active Balance Bms 4S 8S 12S 13S 14S 16S 17S 20S 24S Smart Bms 60A 80A 100A 150A 200A 1000A Lifepo4 Li-Ion LTO Battery BMS
Yes, I do the same. I have a Daly BMS in my truck camper and it is rated at twice the load it will ever see. Never had a problem with it. I tend to derate things from China. Did the same with the 24V to 12V converter, it is twice the size it will ever see for a load.I prefer the 200a also.
1. Will be less stressed in normal operation.
2. Less minimum batteries to keep running, if the SHTF.
3. I oversize everything.
YupYes, I do the same. I have a Daly BMS in my truck camper and it is rated at twice the load it will ever see. Never had a problem with it. I tend to derate things from China. Did the same with the 24V to 12V converter, it is twice the size it will ever see for a load.
You could go even less amps/cheaper on the bms and use those super cheap batteryhookup DC relays and bypass the BMS mosfets altogether.You can get the 150A 8S-24S w/ 1A active balancing for $82.12 ea buying 4 or more.
B1A24S15P
Literally just received another 10kw 15 minutes ago from 18650battery for my 2a balancer 200amp JKs I got a week ago. I do regret not getting the new jk inverter bms now since the kinks seemed to be worked out.Ordered on 01/22 received today; 12 days. Now it's time to find a cell supplier.
