@GazooThere have been other reports of LFE fires and one was using lead acid. The most serious one I recall, other than fhorst's, was reported by @stobbie in this thread and his van was destroyed in the fire The cause was never determined...much specualation as with the other fires. But speculation is good. I am not convinced one way or the other the cell was the cause of the fire is any of these cases.
Ahhh I do remember reading that post. Thanks for linking to it.
In the poll I noticed a spot to vote for swelling. There is a big difference between normal expansion and bloating. Some equate swelling with normal expansion. I don't. Terms are terms but I would have used bloating in the poll instead of swelling
Agree. In the EVE spec. sheet I think they reference that cells will have some mm expansion and contraction.
Having said that this is a great poll and I do thank @solardad for taking the time to put it together. The more we learn the better.
Thanks.
I think in the end I really wonder is there anything that can be done with what appears to be perfectly looking cells..?
Appears that no what what protection gear that you have, fuses, BMS, etc.. will not protect you from an internal short.
So do you try and monitor the temperature of each cell? Batrium does a decent job (what I have) but it only does it at one terminal per cell which would not cover the latest scenario from @fhorst where it failed at the terminal vs cell body. If that makes any sense.
Even then if you do 'catch' a cell failing would turning off the system do anything if the cell is starting to runaway?
Are you up shit's creek unless you try and disconnect the cell and remove it from the pack safely?
Sounds unreasonable especially if you are sleeping or are away etc..
Thoughts?
