Sajjjen, Real world?? Real world does not consist of resting, your charger will never get that luxury when choosing when to stop charging or start charging when your load and discharge is Always at least 1500 watts every second of every day for whole house AC Couple, except for the random vacation in the bahamas you will NEVER have any kind of "resting" period, so your little idea in a vacuum "coulomb counting" is not possible in a REAL world application and so we come here to try and figure out our own personal comfort zone and choosen charging/discharging operating mode, Especially when you, like 99.999% on here have mismatched Branded, batteries to Inverter, to charger that is either solar or grid charger or all in one and then either a different brand BMS, shunt, battery combo. No one has the same everything.
Your ground hog day does not provide resting of any kind, it consists of pushing a charge uphill as fast possible with your random solar output or grid charge setting one day to the next holding a bulk charge Voltage setting on that uphill battle, (2 hours in, clouds form, rain starts, charge stops from solar, and your batteries start the plunge, 2 hours later lightning strikes somewhere and the grid drops for about 10 minutes), if you choose Grid charge you didnt skip a beat depending on your size of inverter (microwave, oven, hot water heater, kids, wife, dryer, and Air conditioner all randomly doing what they want to push you over 10,000 watts and now you have no grid left to charge with, and you hope to get available amps back to work/charging after the random outage, otherwise maybe 2 days later the sun finally comes back out and your solar charger helps you go back to your uphill battle, then once again you hold the line and hope and pray you can reach the top end voltage (at this point youve already learned the hard way, you never set a charger to forcefully hit 100% battery or you will damage or burnout or shorten the life of your battery or BMS guaranteed), so let's say the system hits your Top setting, your specific charger's or your custom top % / voltage mark. Charging stops and you hope you got some top end balancing during the last 2-5%, and then imediately your batteries begin the freefall plunge again back to the bottum because the discharge / load from your house never stops and your "charge operation" isn't coming back on until you hit the bottum all over again.
