agentdiysolar
So i have 2x EG4 3000EHV-48, wired in a split phase (220v [L1-110v/N/L2-110v]) config into an Critical loads panel. Was sized based on what i use and typical loads stay around 1.8-2kw , but have peaks that go to 4.5. All works well (mostly). I have found that one of the inverters always has a higher load (at 975-1000w ) despite my attempts to move circuits on the panel to try to balance them. and when we run our toaster oven one inverter spikes to 3k (and a couple time has gone into overload mode) . What can i do to balance the loads between them ? thought of an auto transformer but not sure if it would work let alone what the wiring scheme would look like.
any suggestion or ideas ? short of going a bigger (or single split phase inverter). as never does our peak load go above 4500W (yet).
