Ah yes.... turning it on the first time.
The full pack voltage also has to go to the last red wire, I think it is lead 26. I am running 14S, so leads 1-15 are the cell 1- and then cell 1+ to cell 14+ and then 14+ also goes to wire 26. If you are running 16S LFP, then the last cell will be lead 17 for cell 16+ and lead 26 would also go to this point. The unused cell wires are just left open.
Then, the fun part. IT DOES NOTHING...
until you supply a charging voltage that is at least 5 volts higher than the current battery voltage. Set your charge controller to a low current setting, but set the bulk limit voltage 6 volts above the pack and see if that will kick it on. It will make a beep, then a red LED should start flashing. At this point, you can disconnect the charger again as you set it up. Once the LED is flashing you can connect the App and check the settings. I was using one of my e-bike battery banks to test it, and since it was fully charged, I didn't have anything 5 volts higher than 58.8 volts. I had to add another battery in series to kick start it. The manual does not mention this at all.
If lead 26 loses power, you will need to kick it again with the pack voltage + 5 volts to turn it on again.
Out of the box, the Charge, Discharge, and Balance modes are probably all turned off. First set the pack configuration, number of cells, type of cells etc. The basic settings for LFP, LTO, and Li Ion are decent, but click advanced, and a larger menu opens and you can adjust everything. If you change a setting, you need to click the paper airplne to send the setting to the BMS memory or it won't take effect. Once you set it how you want it, turn it off again, then power it up again with all of the balance leads connected, and kick start it again with the > pack+5 volts. Then go to the control page and turn on balance, charge, and discharge. Go back to the monitor page and you will see it run the balancer to discharge and charge a little from each cell. It does this to measure the resistance of the balance leads.
Since I have done that, mine has now been running for 105 days now without any problems.
