For the panels, I'd go with 3S, keeping strings of panels with one brand only. As a general rule of thumb when you wire panels in series, the maximal amperage that can flow through the wire is limited to the amperage of the lowest individual panel. So, if you mixed together a string with both 8.4A panels and 7.9A panels, your maximal output could never exceed 7.9A.
So, wire two parallel strings of the 235W panels, and an additional two strings of the 255W panels. Wired 3S, the first two strings will be 90.0V and the second two strings will be 91.5V. That's <5% difference, so your controller will never notice the difference. With four parallel strings, you are required by code to have each string fused/breakered. A combiner box works nicely here. I have the Midnight six breaker box. You'll want to have a 12A breaker for each string. When combined, the total output of the combiner will be ~ 32.6A at ~ 90.7V, more or less.
If you went with the Midnight250 as your controller, you might be able to wire all six panels into one series string, but use this string calculator, and your all-time winter lows with Midnight's string calculator to make sure your max Voc doesn't exceed the controller's limits.
MidNite Solar is the industry leader and manufacture of quality Renewable Energy System electrical components and E-Panels.
www.midnitesolar.com
I agree with Hedges. Wind is likely to be disappointing. Unless you have to have your hat tied to your head when outside, you likely do not have enough wind to make it worthwhile.
BTW, what is the Ah capacity of your batteries? This will be a 24V battery bank? With the two (or 4) strings of panels, the max current they are likely to make is (235W X 6panels) + (255W X 6panels)/25V charging = 117.6A. Even with 85% derating, that's ~100A. That amount of current is about right for a 1000Ah battery, but one single charge controller is not going to handle that much current. The Midnight250 can only handle a max of 62A charging a 24V battery, and the Midnight200 70A. You might get by with a single Midnight150 which has a 94A limit at 24V, but that's pushing it right to it's limits.
