I am assuming the answer is yes But I will ask before I go through the work.
I have 2 LV2424's They are wired into the house panel through a transfer switch. Also wired to the transfer switch is my generator. My question is should I put an isolation relay between the inverters and the generator to avoid back feeding the inverters when the generator is running?
I would like to believe that they have protected the inverters on the output side from this, but I am pretty sure they did not.
