Yes, naturally electronics made in China are online available via shops like Lazada, Shopee and AliExpress.
So are the copper bus-bars.
Transport price is 2.50 USD for furnace or 50 cm of bus-bar.
34* 2.50 make the bus-bar from China 85 USD transport costs.
Local supplier doesn't have this accumulated.
If you are available to find local supplier (Udon Thani province), please let me know. I'm happy to drive and get it!!!
(Google can't find, not even in Thai.
Plain iron enough, several metal types? Nothing.
In the Netherlands it was so easy..)
I don't ask you to understand that not all countries are internet integrated like Netherlands or USA, or have all materials, just accept it.
I can't locally buy M6 headless bolts.
Getting M6 is already challenge, as they mix metrics and inches where ever they can.
Not uncommon to find a hardware store that have M6 bolts, but no nuts....
Welcome to rural Thailand..
Bangkok area is better, sadly 650km drive.
I am using the foam for the 152Ah cells.
The housing 170*173*45mm is used for anything between 120 and 152Ah cells.
Sadly the 152 are known to bloat.
(I didn't know when I bought)
And have several cells that are slightly bloated just by using them, while many aren't.
The reason to compress the cells is to prevent the other cells that did not bloat yet, to do so.
For the ones that are bloated, I think compression will give more problems then it would fix.
Giving them a foam layer will spread out the compression force.
If not, the "pointy" end will get all the force.
Alternative is to not compress at all, and just let the 152Ah cells do want they apparently need to do. (Bloat)
As they want to bloat the 4mm even might be too little.
(One cm between should be enough)
The Bloating after a few months usage is between 0 and 4 mm per cell (on each side)
The 280Ah don't bloat at all.
One might call it production error, or specification, I didn't know they will do.
Now there is no more stock (as the production of the 152Ah is stopped), I hear from sellers about the problems with the 152Ah.
Too many capacity in the housing.
Optical not so nice.
Capacity still is 152Ah.
If you have a better solution, I'm all ears !!!
Not sceptical, serious.
I'm working blind here, not much information to find on this exceptional situation.
Not using the 152Ah isn't really an option.
They are there, function, and I can't get my money back.
If they didn't function or have serious capacity loss...
But they don't, they just don't look nice. (And it's not lithium polymer!!)
I can't really make 2 battery packs of the 152 and 280 cells, and use them individually.
My 3 inverters are parallel connected and need single battery array.
In theory I can make one set of 152's and one set of 280's and connect them parallel to act as one array.
I don't see how that is different from having them already paralleled as cells.
If I'm mistaken there, please enlighten me!
I don't think 2*BMS will make difference on how paralleled cell will behave.
It will costs 2 BMS instead of one.
My DIYBMS is like the chargery, it needs external contactors/ relays.
That would be pricey to double them.
(And I think without real benefit)
Internal resistance never is equal between cells.
Mixing different capacities naturally makes it bigger.
Having them paralleled should make them "one" cell, flattering out the difference between each parallel set.
In the parallel set self the load is balanced between the cells, giving most equal charge and discharge possible.
It's not that one cell will take all the load, but it's divided by the 5.
The one with loweest internal resistance will have slightly bigger load, what is automatically compensated by the other cells who "charge" (or discharge) the one with least resistance.
That is my basic understanding of having cells in parallel.
Even with same brand/type/ manufacturing date the cells will have different internal resistance.
Having them also in series to get higher voltage, still will give difference between each parallel set.
For now my highest load was 120A. (@ 736Ah)
Even starting at 30A (S16 setup, 304Ah) the 152ah cells started to bloat a little.
They just do :-(
As they do I need to live with this.
And make best possible setup for my installation.
My house won't move, doesn't have vibration.
They aren't compressed for this reason.
Stopping the bloating is.
Is that wise???
Or just better give them the space they like to use and accept that they do?
Added benefit would be additional space for airflow to keep the cells cooler.
(That is a concern of me.
Having a 30 cm compact cell block will have problems to release the heat.
During charge/discharge the temperature of the cells will rise.
Center cell probably will be 5 degree warmer then the outside cell.
At start temperature of 30 degrees Celsius (during rest) will this be an issue for lifespan?)
The plan of compressing the cells was made at the start of noticing some bloating.
Now, 10 weeks later, about 1/3 of the cells are bloated.
Between noticing that it isn't flat to a "full" 4 mm on each side.
Uncharted Territory here..
Cells that are produced with pushing the limits of capacity density too far...
They will bloat if not compressed.
Unknown what will happen if they are compressed!!!
Google doesn't provide any answers!
I hope you forum members do!
(That does definitely include you
@BiduleOhm )
