Looks like the rated current for the mppts is 30A/22A/22A
By the way, can someone tell me why most newer AIOs have different amp ratings for the 2-3 mppt inputs??? Maybe someone from Midnite could chime in here and explain to me why it makes sense to not just use identical mppts for all 3 inputs? Genuinely curious as to the reason behind it... Or is it just a "chinese" quirk?
It seems like Sol-Ark is the only AIO out there with identical ratings on all inputs.
@Halfcrazy @Robin Gudgel @SpongeboB Sinewave or anyone else have any thoughts?
I do realize that with larger solar panels these days (400-600 watt range) you do tend to be able to max out mppts with single strings, but if someone would want to put (30) HT450 panels on the One, and string them 5S2P on each input you would end up pretty much right at the rated amperage on mppt2 and mppt3. It's not a huge deal, but I could see some winter time clipping occur at times.
A question along with that. Is there any limitation as to the max power that can be handled by mppt1 on the One? For instance, could someone have (18) HT 450 panels on mppt1, stringed 9S2P? That would be ~450voc/20A (47.2voc x 9 = 424.8) for a total of 8,100 watts!
