cs1234
Solar Wizard
- May 9, 2022
- 2,790
1 minute (timed shutdown not thermal). Push the button on the side and instantly resets the overload shutdown.
I was able to push to 68.7A before hitting the 1 second shutdown point.
We have very few inductive loads at the shop other than a 15HP 3ph 480v rotary screw compressor that has an unloader and soft start...but really to run 3 inverters and a transformer to test with it wouldn't be very valuable. Need a 240v piston compressor that can start under full load to do a real test...
How high can a single leg be pushed while the other leg is at it's rated capacity? The test you ran had the other leg at zero load, right?
