solarstuff
Okay this is crazy...I'm doing something wrong or are all my circuit breakers stupidly designed.
When I screw my 6 awg PV positive cables in to the Midnite Solar mnpv-6 THEY FALL OUT!
The top of the circuit breaker has a bus bar that fits inside the steel ring when you tighten the screw to hold in the bus bar.
I've tried to screw the wired in the bottom of the breakers the same way. They always fall out with the slightest tug.
Am I supposed to do something different? Bend the wire strands over the screw directly? Arg!
Happy to wear a dunce cap if someone can set me straight. Going NUTS.
