Midnite Beta Tester
Just Testing
Disclaimer: I'm not employed by nor compensated by Midnite Solar. I happen to be located near their factories in Arlington, WA and take advantage of the open door policy. I stop in several times a week and try to break stuff! If you stop in and ask if you can attempt to break stuff, they most likely will let you!
I did a 27kW surge test on the Midnite Solar Rosie 6.8kW rated High Frequency Inverter today. COLD START! 12kW of incandescent lights and four portable air compressors. The pumps have a total surge of 15kW and running watts around 7.5kW. Inverter DC input breaker was off. The loads were all switched on, then the Inverter was switched on. The Rosie didn't even flinch! 27kW cold start surge on a High Frequency Inverter! Running watts load was about 16kW. Typical HF Inverters have crappy surge capacity. Not the Rosie! Next week I'll be adding more loads and try to find her upper surge limit. Robin, Midnites President, has told me to try and break their new inverters. I keep trying, but so far not much luck. I did this video, then repeated the surge tests about 10-15 more times.....Stay Tuned!
