nscottsdale
- Aug 26, 2021
- 70
I have my setup detailed here (https://diysolarforum.com/threads/pre-flight-peer-review-16kw-system.54794/#post-712820 )
Question one
I am working on configuring my pair of LV6048 in a split phase configuration. The two LV6048 battery connections are paralleled on a bus bar that feeds two parallel EG4 batteries.
The spec on the EG4 says Max charging current is 100 amps.
I have two EG4’s in parallel , do i set the rate to 100 amps as the lowest safety net or 200 amps because i have two batteries?
Or do i set each LV6048 to 50 amps so that 50 plus 50 = 100?
Question Two
The LV6048 has a setting for "Bulk charging voltage (C.V voltage)" but the EG4 spec has
a)"Charging voltage rec. - 58v"
and
b)"Rec bulk voltage - 57v"
c) Bulk/Absorption 57.5v
Which one to use?
Question Three
The setting 34 to 39 are for "Battery Equalization". What does this do? It cant possibly see down stream and equalize Batteries that are parallel on the bus.
Question one
Question Two
and
Which one to use?
Question Three
