My cells are inside the RV. I added insulation to the larger solar/battery compartment and then insulated around the batteries too. The RV is at the storage lot, so it's going to get cold in the winter.
The smoker controller runs on AC, but it is an aftermarket system with multiple temperature probes. It's designed to activate a fan to push air into the smoker to adjust the temperature. I don't know that it could power the warming pads (too many amps probably), but a relay would solve that problem. It's from BBQ Guru. Mine is pretty old, no longer sold.
