My adventures building a DIY Zn/I flow battery
Wherever you have the ability to pump large volumes of water and store them, this is definitely the best solution.
Building a tall tower and hoisting heavy blocks to the top would probably be a bit more efficient, but very tall and very heavy get hard to manage pretty quickly.
At least blocks should stay where you put them for a long time without evaporating.
There are many problems with gravity batteries that use weights, in the context of towers it has never worked so far due to basically problems with keeping weights stable in the wind. The only viable trials up until now are using mine shafts, at least to the best of my knowledge. Water has decent density at 1 ton per cubic meter, so you will never be able to achieve using blocks what you can achieve with even a regular pool full of water. The water evaporates but it also can collect from rain, so you can also gain energy you didn't put in.
It all depends on what you make your blocks from. Lead, for example, is 11.3 times more dense than water. A visit to the Flint, MI scrapyard should provide plenty.
Around here, you can't pump water very far up a hill because the land is flat, and you can't dig a hole very deep without hitting water. A tower would be the only way to gain the height needed, but a hurricane would push it over. I guess I'll stick with batteries!
So, are anyone of you actually saying that storing excess energy in the form of mechanical work (kinetic energy) done during the day when there is a surplus and later tapped into this potential when there is a need and that at the same time, such a system can be scaled to such a level there is enough energy stored to last a standard household for 2-3 months when excess input is too low ????
That would depend entirely on the "excess input" you speak of. Considering that 1kW is 1,000N-m/s, you need to let a 102kg mass (near earth's surface) fall 1 meter in 1 second to get 1kW (excluding losses). So now, 1kWh of power is that same 102kg mass falling 1m/s for an hour (3,600 seconds). Or it could be (3,600*102) = 367,200kg falling 1/3600m/s for an hour.
Put another way, each MWh of stored energy converted to power would need ~102,000kg capable of falling 1m/s for an hour. I think a 3,600 meter high tower is impractical, so I would have no choice but to build a much lower one. A 36 meter tower would need 100 times the mass moving 100 times slower, so now we're talking about lifting about 11,230 tons (sorry for the units system change) and letting it dangle in the air until you need it. That is per MWh, so if you need more power you need more towers. You also need a safe cable and gear arrangement on each tower to lift the masses and harvest the power.
The amount of solar energy that hits the earth is truly amazing (roughly 1kW per square meter at the surface). Do what you can with it and let the rest grow flowers. Saving it in a bottle for months at a time is somewhat impractical.
The problem is not hurricanes. Even normal wind speeds are very problematic in these approaches. I would suggest watching these videos, which summarize a lot of the technical problems with this idea. Also note the titles of the videos are overly antagonistic for views, I don't view the idea as "dumb", but do recognize it has problems that make it mostly impossible in practice.
Also I would like to keep this thread dedicated to its main subject, so feel free to open a separate thread if you would like to continue discussing gravity storage.
I wonder if anyone has tried collecting together and feeding info on flow batteries into one of them new AI programs to see what it could come up with. I know they had one take a stab and a fusion reactor.
I have given it a try, it definitely sucks at chemistry or I suck at prompting AI.
If you are in the Neatherlands or close in the EU, we will be holding a free workshop in Eindhoven in April, it would be great if you can attend (https://www.eventbrite.com/e/flow4u...utions-tickets-851447120257?aff=oddtdtcreator). We will be explaining our DIY flow battery design as well as giving away some kits - potentiostat included - as well as allowing you to have a hands-on experience putting a flow battery together. Let me know if you have any questions!
Note these are small flow batteries, for research and characterization. Also free lunch, so make sure you only register if you do intend to come.
For LiFePO4 the cost per kWh is still above 130 USD. It is definitely still too early to be talking about anything at large scale, but flow batteries - even at these lower energy efficiencies - can often make better sense than Lithium batteries. The 75% EE is only my first practical result, I'm sure we will improve things with time as we gain more experience with the chemistry.
You can make your own lifepo4 battery with materials purchased from 1688 for ~30$/kwh not including shipping and tax.
Hi all, I'm Kirk, I've been collaborating with Daniel on this battery project. We set up a website https://fbrc.dev/ and just got a small grant to continue the work. I'll be working on mostly the engineering of the stack design.
I see groups are experimenting with prussian blue and prussian white
For flow batteries? Or for Na-ion?
Yes, LFP is cheap, and benefits massively from economies of scale right now. Beyond just up-front cost, I think it's important to consider safety, cycle life, and the sustainability of the materials needed to make the battery, as well as how easy it is to recycle them at the end of life. Also, the cost of clean/dry rooms, solvent handling, calendaring equipment, etc. to produce nonaqueous intercalation batteries like Li and Na-ion means the upfront capital investment to build a factory is massive - which is why we see so many "gigafactories" being announced - the capital expenditures must be huge to get to the scale where one can profitably make Li-ion batteries. And even then, the profit margins are not that large. Recycling for Li-ion is coming around, but unmixing a slurry electrode is a big battle with entropy.
In contrast, flow batteries are safer to produce and use (aqueous, no risk of fire/explosion), have fewer degradation pathways and longer cycle life, tolerate wide SOC ranges, can be made from more sustainable materials (ie. Zn, I, Mn, Fe... I'm not counting V) and as far as manufacturing them... well, we can test and assemble small-scale ones in our apartments. The same cannot be said for Li-ion, where you would have to handle anhydrous propylene carbonate solvent and fluorinated salts. This general barrier of having expensive equipment (like a glovebox, Karl-Fisher titrator, etc) scales up to the manufacturing line in terms of the strictness and purity required. Flow batteries, on the other hand, are more similar to building a small chemical reactor, and water is always easier to work with than hazardous solvents. There are still plenty of challenges, of course...
These are some reasons why I think it's still interesting to work on flow batteries even though Li-ion has come down a lot in price. I think it's possible to eventually get to something cheaper than Li-ion or lead-acid, with longer cycle life, safe, and more sustainable - the main downside being less energy density.
Looks like Sodium mostly, and Li-ion. Seeing it mentioned more and more in regards to new battery tech. It looks like it can be in liquid form, soooo...
This discussion intrigued me. After some Googling I found interesting paper promising solution to dendrites formation https://www.nature.com/articles/s41467-024-50543-2 - I have no chemical experience whatsoever, so no idea how accessible that will be to diyers.
The chemistry is not super easily accessible due to the synthetic requirements (the zinc pyrophosphate complex must be synthesized), which requires heating under vacuum to concentrate the product.
However the main issue here is solubility. Zinc pyrophosphate has a solubility of only 0.9M, so a flow battery of these characteristics is limited to around 32Wh/L, which is quite low compared to other Zinc iodide chemistries, which can reach almost 6.5x this energy density. This is the reason why the paper doesn't mention Wh/L but only mW/cm2.
15,000 catholye + 15,000 anolyte at 35Ah/L would give you 525kAh which at a mean discharge voltage of 1.23V would give you 645 kWh, this is 0.645MWh, so very massive system. At 1mL per cm2 of electrode area you would also need to have 1500 m2 of electrode area, which at a standard 25cmx25cm per cell would imply having at least 24,000 cells. This is a massive system. Probably a couple of containers filled with stacks of cells to process what is literally a pool of electrolyte. Since the energy efficiency is 70-75%, you will need to put at least 0.86MWh in to get that 0.645MWh out.
At bulk prices of:
ZnCl2 - 1700 USD/ton
KI - 2900 USD/ton
NH4Cl - 450 USD/ton
For 30,000L you would need 8.17 tons of ZnCl2, 3.20 tons of NH4Cl and 19.9 tons of KI. The total cost of the salts would be 32.1K USD.
The above doesn't include pumps, tank costs or cell costs. Note that since no ion selective membranes are used, this is going to be significantly lower cost compared with a Vanadium based system. Big systems have significant additional issues - for example pumping efficiency becomes a huge concern - so I'll have clearer costs for you once we implement the first 25x25cm cells.
We are however FAR from anything at this scale. Right now we are focusing on the small scale. Once everything is optimized the costs for larger scales might also drop further. Hopefully significant improvements in the energy density are still possible since the solubility does allow for much higher densities.
Out of curiosity, why are you using the various salts, and not using zinc iodide directly? Due to availability, or other reason?
Hey danielfp248, do you know if GDE ORR & OER can be used in flow batteries? For example at high or low pHs, or is the overpotential killing the efficiency? Oxygen would be a cheap starting material.
Also, do you see uneven dendrite growth on Zn side at normal conditions or high currents or high cycle counts? Just curious as I experimented once on a solution to mitigate uneven Cu-plating & deplating. Wondering if stabilizers could be helpful in your project for increasing battery longevity.
Hi Everyone. I just wanted to let you all know that the project to build Zn-I batteries is still ongoing. This will be the first chemistry in our small scale flow battery research kit and the focus of our larger scale flow battery setup too. I am no longer checking this forum often, so please follow our progress at fbrc.dev and at my blog.
