Ampster
Renewable Energy Hobbyist
Did you get custom cables? If so, from who? I can crimp 2/0 cables but 4/0 get a little messy without the correct die.I'm waiting for the 11' 4/0 battery cables to connect to the Sol-Ark.
The installer is ordering the (custom) cables, so I don't know where they are getting them. When I was considering doing this battery install myself, I was planning to buy cables from Windy Nation.Did you get custom cables? If so, from who? I can crimp 2/0 cables but 4/0 get a little messy without the correct die.
How many batteries will you have in total?I did not expect the Pytes IC enclosure to arrive for another couple of weeks but since it was here, I assembled it and put the other three batteries in it to test. I only have a permit for the four batteries which are running in the external enclosure but since the internal enclosure has wheels it is easier to move 300 lbs of batteries out of sight until I get my final inspection. I was impressed with the rugedness of both enclosures.
Seven for a total of 35 kWhs, Four in a V-BOX-OC external enclosure and three in a V-BOX-IC internal enclosure..The engineer said we would avoid lengthy review by the Fire Marshall and a quicker permit process if we only went with 20 kWhs externally. That is why I am using two stages, one for inspection, and another, after inspection.How many batteries will you have in total?
Here is the screen on the Sol-Ark.I am trying to figure out the export limiting function of the SolArk. In Solar Assistant it is edited unde Configuration / Inverter / Work Mode Detail. I don't know where those settings are on the LCD screen on the SolArk. I have not invested time to learn PVPro since we will be migrating to My SolArk in a few days.
I had assume the limit only applies toward the DC coupled solar. For background I have about 3kW of DC coupled solar and had previously set that limit to 2kW. The other settings are, Work mode - Selling first and Energy pattern - Battery first. At about 9 AM my DC solar drops from 2 kW to 100 Watts until about 5 PM. As a test I increased the setting to 7.5 kW and the result was that the DC solar fired up again. So in conclusion the total is based off both the DC and AC coupled solar but the only solar that can be controlled by that setting is the DC solar, when the grid is active. This off course is because the grid frequency does not change and that and voltage are the only ways to modulate the AC coupled solar. The DC coupled solar can be controlled by the MPPT controller.
Are you operating without battery communication? I see in your later posts you have cell voltage of 3.5V. I'm operating with Comms and V5 batteries sit at 56.7V when 100% SOC.I checked and Float was at 56.7 and I set it to 55 to see if it takes. I prefer a lower setting about resting voltage but I want to see how the TOU settings affect it.. The one thing I did find that I had disabled the TOU check box when I disconnected my pack and that may be the issue. I will wait til 9PM to turn the grid back on and do a full reboot at that time to be sure all the settings take. I will also see how much the percentage of the pack is at that time as well. My house loads are currently about 1500 Watts and my battery is at 96% and declining about 9% per hour so I should see about 75% left in the battery when I turn the grid back on at 9PM.
Yes, battery is communicating with The SolArk so the BMS is telling the SolArk how much to charge. Interestingly when at 100% it puts about 60 Watts into the battery at 3.55 Volts per cell. At 4 PM the batteries start discharging if the solar is not enough to cover loads. Since there is no longer a small current going into each rack module they settles to 53.1 volts or 3.32 volt per cellAre you operating without battery communication? I
Per Sol-Ark tech support I had to set my batteries to discharge to 99% during solar hours. It was the only way to prevent the PV dropout I was experiencing. I usually achieve 100% SOC shortly after 5PM, but never achieve 56.7V due to little solar. I hope I'm not creating cell imbalance. I guess I should purchase the Wi-Fi dongle.Yes, battery is communicating with The SolArk so the BMS is telling the SolArk how much to charge. Interestingly when at 100% it puts about 60 Watts into the battery at 3.55 Volts per cell. At 4 PM the batteries start discharging if the solar is not enough to cover loads. Since there is no longer a small current going into each rack module they settles to 53.1 volts or 3.32 volt per cell
It all depends on when the balancing starts. You can also use hyper terminal on the console port of the master battery to query individual batteries and see individual cell voltages. Not as convenient as the WIFI module because to use hyper terminal you have to be within the fiance of the cable length to the master battery.I hope I'm not creating cell imbalance.
The new communications cables have been working for at least a month but I am going to run some diagnostics and bypass those cables. I do have a cable tester. I am also going to reach out to Pytes to see if there is any way to confirm that the Pytes is sending data to the SolArk. I know part of the cables are working because Solar Assistant can see the data from the SolArk. I did reboot Solar Assistant, the SolArk and the Pytes batteries.Could that be the problem again?
Is it connectecd to your Master battery? The three LEDS are green with the comms one slowly blinking. You have to use the application Solarman to view it on your phone or the website at solarmanpv.comI was thorough in seating it
