alexzan
- Apr 15, 2020
- 49
I am seeking advice and suggestions regarding an issue I am experiencing with my off-grid solar system. I have a non-isolated inverter (LV6548), and I recently noticed a voltage leak between the inverter ground and the earth (between 2 and 95v observed today). Upon investigation, I found that my PV panels, which are currently just laid on the ground, might be the source of this leakage. When I disconnect them the voltage goes away.
Concerns:
- Mounting Panels to Wooden Frame:
- I am considering mounting my solar panels to a wooden frame to isolate them from the ground and potentially resolve the leakage issue. Would mounting the panels to a non-conductive, wooden frame help in preventing any grounding conflicts and leakage currents? What about when it rains, wont there be some conducting? I am not sure of the solution here.
- Grounding the System:
- My system is entirely off-grid, with no AC input (although I might consider adding a generator later). I am contemplating whether I should install a grounding rod or keeping it a floating system. Would grounding be beneficial in my case?
- Grounding Rod Installation:
- If grounding is recommended, could anyone provide insights or resources on proper grounding rod installation for an off-grid system housed in a metal shipping container?
Additional Information:
- The inverter manual specifies that only certain types of PV modules are acceptable and warns against connecting any PV modules with possible current leakage, such as grounded PV modules.
- The system will remain off-grid, and I might consider adding input from a generator in the future.
Questions:
- Would mounting the PV panels to a wooden frame effectively prevent grounding conflicts and resolve the leakage issue?
- Is installing a grounding rod recommended for my off-grid system, and if so, how should it be done considering the system is in a metal shipping container?
- Are there any specific considerations or precautions I should take while grounding the system and mounting the panels to ensure safety and compliance with electrical standards?
