garetwo
Hey tims..i hope you are well..Grounding is for personal protection against electrical shock.
Lightning protection is a completely different and separate system.
I am about to now research these as separate, but I think you have more lurking in your mind.
I have never done grounding for lightning, it has never been required (that I am aware of), so I have to look at that. But, since lightning is the only electricity that wants to get back to ground, I could sure see bonding all of the frames and running them to ground but NOT bonding that to the ground common to the output of the inverters. If the two ground systems get tied together, is it not just one large ground grid with a potential for lightning to follow the path to the house ground, especially if the connection at the panels is loose or gets disconnected?
30 minutes later...I should just delete this post as I read up on lightning protection....but I am leaving it so all may poke the necessary holes in my thinking. There are probably many like me who have NEVER done lightning protection, it is NOT what I thought it was.
