rwhite8134
I wouldn't recommend Solar Edge for a solution with batteries because you are forced to use their very expensive batteries. However, the single solar input isn't a restriction. Each panel gets and optimizer which means you've got a good MPPT on each and every panel, you can have strings facing in every direction and partial shading, each panel will still produce at their peak.
I was planning on using the TS4-A-F (RSS) and not the TS4-A-O MLPE as it seemed that recent modules do so well themselves with shading anyway. I recall coming across a YT video of someone comparing two side by side modules with and without a TS4-A-O and the one without the Tigo produced more with identical shading. Not hard evidence of course but was interesting. Can't seem to locate the video now though. If the consensus is that optimizers indeed make a difference, either with shading or fewer trackers the extra cost is worth it over a RSS only MLPE.
Yes, you'd need more individual inverters if you go with the Schneider, but the individual inverters cost half the price. And you can customize the system to exactly your needs. Want more solar? Add more charge controllers.
Also, if something fails, you can pull that single component and not take down major sections of your system.
You've got a great point there. However the Schneider MPPT controllers appear to have a single tracker from what I can tell, I can't see it spelled out exactly, but if optimizers would solve that then I guess the Schneider is back at the top of the list.
